wood help? can't think of a good title
See more from nwcatman
nwcatman
south texas
i cut a mesquite limb that a neighbor brought by into bowl size blanks today and realized it was WET WOOD! since i use old " foundwood" all the time i have never dealt with "newwood". i have some ANCHORSEAL coming in but i wasn't able to cut out all the pith in all the pieces and will be awhile before i can turn the blanks. can i/should i coat the surfaces with anything to keep it from drying out in the meantime? i stored the blanks in my shop to keep em out of the sun. THANKS
markgum
Keenesburg, CO
Depends on how hot and dry in your area. How long before your Anchorseal arrives? To be safe I would coat the ends in wax.
marcruby
Warren, Michigan, USA.
I'd rough turn them now, and then stuff them in plastic bags with some shavings. That should keep them damp enough until relief arrives.
Marc
leehljp
Member Liaison
Tunica, Mississippi,
el_d
Lockhart, Tx, USA.
Mesquite doesnt split like other wood does. I will cut the branches off trees, strip them of their bark and leave them out on the porch until I can get to them, somewhere about a couple of weeks. I will see very small amount of checking on the ends. I have even used mesquite that was drying for only a week with good results.....
I usd to spray whatever I had to seal the ends and it held nicely...
MesquiteMan
Retired Head Moderator
San Marcos, TX, USA.
According to Texas A&M University, the authority on mesquite, mesquite is the most dimensionally stable Wood in the world. I use a TON of it and have made really nice furniture with it so wet is shows on the surface when I cut it. The joinery is just as nice today as it was when I made it! Pretty awesome wood!
stolicky
Loudonville, NY, USA.
I don't know of many special qualities of Mesquite (I'm not an authority on wood) but I can say that the likelihood of cracking is generally high (almost guaranteed) if you leave the pith in it. If you don't have time to rough turn the wood as recommended above, you could just put it it plastic. I wonder if mesquite will spalt?
