What Mini / small table saw are you using ?
1shootist
Frisco,Tx
I am in the market for a affordable mini table saw . I've researched them for the last few days and there looks to be everything from a ebay $65 hobby saw up to a $500+ Byrnes Model Maker ... If I could have what I wanted I'd buy a Byrnes. Though what I can actually afford is something between the two.
If there are any mini table saw users here would you share your thoughts on what you have and if it gets the job done for you.
There are so many listings for mini type saws , most cheaper ones look totally worthless but surely some would get it done properly.
I had thought about a MicroMark mini tablesaw...they have 2 sizes..a roughly 9" & a 12"..though after looking into reviews ..both are greatly underpowered for hard pen blanks.
Thanks all !
dogcatcher
TX, NM or on the road
I used an antique 8" Craftsman table saw that was made in the 39s or 40's. Homemade sled. I am in Abilene, but I found it in Arlington on Craigslist. At one time I also used a 10" 1970's Craftsman table saw with a sled. The 8" was good for pen and bottle stopper size, for bowls and larger stuff the blade was a limit in cutting the big stuff.
My favorite segmenting saw was a Makita 2708 with a homemade sled. Unfortunately it was not mine, but he let me use it when I wanted to.
DrD
Columbus, Mississippi
If you were closer, I would make you a deal on a high precision cabinet saw which works beautifully with thin kerf 10" or 7 1/2" blades. Comes with precision Woodpeckers Cross Cut Sled; FLAT granite work top, 1 3/4 hp, 110v, can be changed to 240v, left tilt. Put a nickel on edge, anywhere on the granite table, fire it up , make a cut, the nickel doesn't even wobble - . Run0ut on the blade is non-existant. Great saw. I no longer use it; converted my shop to track saw & SCMS.
TonyL
Georgia
With all of these smaller/mini/micro saws, you may want to me mindful of maximum depth of cut and HP. Enjoy!
What do you plan to do with it, build models with Balsa wood?? If so any will work. Is it that you do not have room for a full size saw or are you afraid of them?? Would a job site saw work for your needs?? Can you do what you want with a bandsaw or handsaw and miter box. ??? Mini saws are cute and that is all they are. Unless you do model building they can be useful. That was what they were built for.
showcaser
Virginia
Microlux but looking at that Byrnes with the sliding table. Full time RVer so weight is a consideration.
mark james
IAP Collection, Curator
Medina, Ohio
I am a huge fan of the Byrnes. But... I did buy the sliding table and seldom use it. You can with minimal effort make jigs for the uses of the sliding table. It (the sled) is of excellent quality, but I would not buy it again. And I say this as I use the saw for almost every segmenting blank/design I make. I have cut through 3/4" Oak pen blanks - slowly, but if you are not in a hurry and know how to use the machine, all is well. I'd without doubt buy the Brynes again - but I do realize the cost factor.
leehljp
Member Liaison
Tunica, Mississippi,
Another question for you is: How good at creating and making your own with precision sled and even table saw? I turned a circular saw upside down under a home made table and added a sliding table to it, along with adjustments for tight fit but smooth action. I did this when I lived overseas and purchased numerous 120mm blades with kerfs of .9mm, 1.0, 1.1, and 1.2 mm. I have lost a micro adjuster that can adjust rips by 1/128 or better, but it is somewhere in my shop. Haven't used it in a while.
I use to see this alot on job sites.
1shootist
Frisco,Tx
I appreciate recommending the ideas,
I do have a full size table saw..though I am apprehensive using it with small, pen size material due to a physical concern..I have only my left arm..holding anything, even with a foot long kick stick close to the saw blade gives me a severe case of willies. Plywood, sectioning a 2x6, not an issue...pen blank size wood, big willie issues.
And its a saw with no miter slots..though even if it had a slot or two so a sled could be utilized I'm not sure how I would feel about doing so...,for small pieces.
I've been researching for the past several days..the Byrnes is pretty much the one that checks most of the boxes. Others have some good qualities though lack a major box or two, such as the cutting height is poor, hp poor , no miter slots, blade options due to size etc....I've decided..unless something else at a good price surfaces, I'm going to save a few dollars here and there and buy a Byrnes setup.
Just remember a spinning blade is a spinning blade. You can get kickback on any saw. You can have digits cut off with any saw. Smaller does not make safer.
DrD
The safety issues are why I now primarily use a track saw. With my set up I can accurately and reproducibly cut material 1/16" thick, cut pen blanks, breakdown sheet goods. Not quite as safe as a SawStop, but a whole lot more accurate, at a lower cost,
1shootist I do understand the "willies." So far after 2 accidents with cabinet saw the orthopods were able to get everything reattached and working - not so with toes on right foot after a fight with a running lawn mower.
SawStop/Festool makes a dandy job-site saw, but it is up there in price, ~$1000 or perhaps even more now.
Mikeyt
I have the Byrnes table saw. As many people have said it is worth every penny. It is accurate and works great for pen blanks as other cuts. I also have a full size table saw. I will use my Byrnes saw over the full size for anything that will fit on it. Very powerful and great. If you have to sacrifice for it you will be glad you did for this saw.
mark james
Medina, Ohio
I could not agree more. And I do not have the tilting table.
idance1
Grand Prairie
what saw was this ?
