v-belts for my Delta drill press
Auto Zone or any other auto supply...Tractor Supply, etc. Just take the old ones in so they can measure. Or, measure around the pulley set up on your drill press. I don't think there is anything special about the v-belts on a drill press. Or, am I missing something?
Or here if you want to pay shipping and wait a few days. http://www.ereplacementparts.com/v-belt-p-955085.html
I'm sure there are many other places.
Do a good turn daily!
Don
Anyone know where I can buy new v-belts for my Delta 18-900l drill press?
Any industrial supply such as Grainier.
Belts usually have a number on them, if it's worn off for some reason just measure the width and circumference of the belt and compare to the listing in the catalog for the same size.
You can usually fudge a bit as long as there is enough adjustment on the motor mount to allow for one a bit longer or shorter.
Industrial drive belts are different than automotive belts. Automotive pulleys have a deeper groove than industrial so the automotive belt can bottom out in the pulley causing it to not come in contact with the groove sides. Most larger cities have a local supplier that make the belts and are massively cheaper.
