Troubleshooting vacuum pump
GuzZzt
Gothenburg, Sweden
I bought a vacuum pump (2 Stage, 2.5CFM, 12/3 HP, 3x10-3 Pa) that I have connected to a 12l chamber. I get a vacuum around 27" Hg but not better than that. I expected it to get closer to 29". I can see some bubbles in the oil window on the pump, not sure how to get rid of that. I have tried twice to change the oil but it only slightly improve. How can I troubleshoot this?
duncsuss
Wilmington, MA
I have a T-junction on my pump with a gauge right there and a valve (to which I connect the hose). It lets me measure the vacuum the pump is pulling without anything else connected.
Gary Beasley
Marietta, Ga. USA
The seal on the tank should be thoroughly checked, expect too such a large tank may take a while to stabilize at max vacuum. Also you might want to check the accuracy of your vacuum gauge, it may be off.
