Hello everyone, first post.
I just finished a southwest twist (not the mesa) from PSI and I have a problem. The refill will not retract when I twist the upper barrel. If I put pressure on the refill tip it will pop back inside the body. I've changed the mechanim, spring and refill but still have the same results. The spring is positioned according to the instructions.
Any help would be greatly appreciated.
