Sanding small parts to square?
Woodchipper
Cleveland, TN
I have a box full of cutoffs that vary in sized from 1/2 inch to one inch in length. All are from 3/4x3/4 blanks. Problem is they are not square when cut on the bandsaw. I have a combo belt sander and disk sander. Wondering how to hold the small parts to square them for gluing on tubes or other blanks. TIA.
Use a small wood screw clamp (hand screw).
I have some 4" hand screws which are a good size for what you're looking to do.
I like using them with the TS, router or chop saw.
Another option is to build a sled wherein you can clamp the small pieces keeping your hands safely away from cutting tools.
Thanks, John. There is a gap between the miter and the sanding disk. Measured with I got the unit and it's a true 90 degrees. Make an extension of some kind to allow sanding closer to the disk. Just what I need...something else on the to-do list.
I am for the TableSaw with sled. For me, it took some time and was a project of its own. BUT, once done and squared, perfect cuts over and over. I made "adjustments" a part of the sled and if I take an hour or so when I haven't used it in a year or two, I have been able to get everything back into alignment and square.
Dozens and dozens of perfect thicknesses done from a sled.
