Questions about Robinair 15310 vacuum pump and chucking
randyrls
Harrisburg, PA 17112
Hello; I am setting up a vacuum chucking system and looking at a Robinair 15310 vacuum pump. After a LOT of searching on the internet, I found a fitting to convert the 1/4" flare fitting on this pump to a standard MIP connector Flare Fittings from FAMOUS PLUMBING SUPPLY near bottom.
But I still have some questions from anyone who uses this pump or ones like it.
Is an oil-less pump less hassle than a pump that takes oil?
Does this pump create an oil mist? Does it need a filter for this?
For vacuum chucking on the lathe is 1/4" ID tubing sufficient, or does 3/8" tubing give better results?
Is there anything I don't know that I should??
Thanks for any experience you can share....
I have a Robinair 15500 pump. It does create a mist at high flow rates, such as when first starting to pull a vacuum. Once the flow rate slows as the vacuum comes up, the mist goes away. In a vacuum chucking scenario, I have no idea what type of flow rate you would have. I just used a sponge and put it over the exhaust port to slow/contain the mist when first starting. I'm sure there are filters available for this.
Jake
That's my favorite question in a long time. I would be pretty certain the answer will be yes for everyone on the forum.
Oil mist is not a big deal, just put a cheap automotive gas filter on the outlet, no problems then. 1/4" hose is fine.
