What is the size difference (if any) between the two different bushings?
navycop Member Joined Nov 4, 2010 Messages 2,334 Location Virginia Beach, VA 23454 Dec 25, 2011 #1 What is the size difference (if any) between the two different bushings?
ToddMR Member Joined May 3, 2010 Messages 1,715 Location Columbus, OH Dec 25, 2011 #2 I don't have the specs, but the WS III leaves more material on the finished pen. I have a set of both in the shop. So the diameter on the III should be bigger than the II.
cwolfs69 Member Joined Apr 24, 2011 Messages 916 Location portsmouth, va Dec 25, 2011 #3 WS II, both ends are .474, on the WS III one end is .551 and the other end is .523. check the chart is library. http://http://content.penturners.org/library/general_reference/bushingsandtubes.pdf
