Pressure Pot for casting
Dranom
The pot was modified to be used for resin casting. The middle mixer was removed and a plug was installed. *kindly refer to the pictures posted
I personally used these pots to cast alumillite without any problems. I have a few of the pots available so im selling the new ones to make some room at the shop.
DIMENSION:
Inner diameter: 14.5"
Depth from the middle: 18.5"
For Casting:
In regards to additional modifications on the pots i'm using I replaced the safety valve to 90psi so i can cast to 60psi. The valve it came with goes off at around 55psi. I also installed a male quick connect on top on the air inlet so i can set the pressure at 60psi. Very easy modifications
I went this style of pressure pot since its more secured rather than going with the horbor freight pots. Yes its a little more than the HF pots but these have more room to put more molds and more secured.
NOTE: This listing will come with the stock valve.
PRICE: $425 obo SHIPPED US48
