1JaredSchmidt
What would be the cheapest way to get set up with pressure casting. I would like to try to pressure cast some blanks. Need Help!
Yes, use 4 inch schedule 40 (or 80 if available) PVC pipe and some fittings. The chamber won't be very large but it will work. Make sure you get 'solid core' pipe, not the 'foam core'. The core type should be printed on the side of the pipe. If it isn't, look at the end. Solid core will have a uniform appearance while the foam core will look like there is a 'spongy' portion with solid material on the inside and outside. The recommended safe working pressure should be labeled along the side of the pipe. The burst pressure is well above the working pressure.Originally posted by 1JaredSchmidt
Is there any other way to get set up for about 40 bucks?
Yep. Check out the IAP library. Here is a link to the index (thanks to Randy_):Originally posted by 1JaredSchmidt
Is there any tutorial on how to get set up? Also,is there anyone that can tell me or give me a tutorial on how to stabilize and pressure cast blanks? Thanks for your help!
Originally posted by gketell
Some people use pickle jars. Scares the H out of me but they would be cheap. Then just plumb a female airhose quick connect to the lid. Hook up your air compressor hose with a male-male connector and dial up the pressure you want; disconnect the adapter from the lid and you are pressured. Plug just the adapter into the lid to release pressure.
Cheap. ???Safe??? But cheap.
GK
