sandking
I've done a search and can't seem to find a detailed way of casting inbedded objects with the HF pressure pot. I have no idea what needs to be done to the pot or what materials to use for this setup.
This is what I'd like to do.
As wedding favors I will be turning wine bottle stoppers. I plan on using a fostner bit to drill out the end of the stopper so that I can epoxy a medallion with our names and wedding date. I would like to cast a clear resin over the medallion so that when I turn it it will be under the resin.
1) What materials do I need for the clear resin?
2) What do I need to do to the pressure pot to get this to work?
3) What are the steps in casting something like this?
Thanks in advance.
Thanks in advance.
