Pair a power supply and switch with a LED light fixture.
TonyL
Georgia
I am sure there are some rules to follow. would love to hear what all of the experts have to say.
Need to know the specs for the LED ... voltage, current. . Easiest done with a battery.
Yes we need more info Tony. Are you installing a new one, retrofitting something, or creating something of your own?? The LED platform is relatively new and they are constantly changing and coming out with new things. Any new light is basically self contained.
Electrician I am working with on a building project is inatallin all led lighting and dimmable. he describes it as zero to 10 volt to run them.
Polarizing luminares, lots of special effects.
Only takes money
So what are your performance requirements?
Thank you for the direction: 24 watt, LED lamps. Going to use it to cure Solarez.
I may going higher on the wattage like 50. Both 12 volts.
Would that work with that stuff??? You need a high uv output. I maybe wrong I have not looked into that stuff. I can not help you. Sorry.
Thank you. What I bought works fine..I want something that works and mounts better. I am aware of the nail lights, but I am just really looking for how to match a PS to a fixture. I also don't want to deal with batteries.
Thanks again.
