Mold Rack system
longbeard
West Virginia
This thing awesome!!!
This is a "mold rack system" from https://ptownsubbie.com/products/pressure-pot-rack
It will clearly hold 16 of the tube-in molds (4 on each rack, depending on the size of the molds) or 4 of the block molds (1 on each rack). And the clear top will prevent the air from the intake blowing your resin out of the molds as you add air.
Thanks Fred Wissen
Great product and great service
Not sure why the pics are sideways. Sorry
Harry
Looks good but what is a standard size pressure pot? Is that the 2-1/2 gallon size like you can get from Harbor Freight? Also, what is this made of? It looks like that high density plastic stuff which would be great I think. I can't tell from the picture but does it have a handle to lift it and to lower it into the pot?
It fits the Harbor Freight pots perfectly.
The material is HDPE.
Not a "handle" per say, but the side supports is cut out in way that makes it very easy to hold on to while lowering and lifting it.
Harry
Here you go harry!!
