A client recently saw one of my Aero stylus conversions and asked if I could make one for her using the Le Roi Elegant. I sent a message to Smitty asking how the tip was attached to the grip. He responded that the tip was pressed into the grip ( Thanks Smitty ! ). So, I took a transfer punch and a hammer and sure enough the tip came right out.
Since the diameter of tip coupler on the CSUSA stylus was smaller than the inside diameter of the grip where the tip coupler would be pressed into, I decided it would be just as easy to make a new tip coupler than to make some kind of adapter.
The new tip coupler is make from aluminum and all dimensions are the same as the original except the end that gets pressed in was made to be a press fit into the Le Roi grip.
Here is the finished product. A Le Roi Elegant Stylus with blue and white web Tru-stone ( the client picked the blank ).
As always, your comments and critiques are welcome.
Thanks for looking.
The grip and tip after I pressed the tip out.
The grip with the CSUSA tip coupler ( top ) and the custom tip coupler ( bottom ).
The grip with the new tip coupler pressed in.
To the right are the stylus tip and the trim ring.
The grip with the assembled stylus.
Thanks for looking.
