JR kit parts
jamesbil
Ireland
Hi all,
Its been a while since I was here..
Just went to turn a JR fountain pen I got from timberbits some time ago only to find the threaded part in the cap is broken, on checking 2 others are the same.
Unfortunately they don't have parts anymore.
Any Ideas?
James
jamesbil
Ireland
Unfortunately the part of the thread that goes inside the silver bit is broken off too. So it can't be repaired. Anyone know if other kit parts are compatible with the JR?
jjjaworski
Las Cruces, NM
Perhaps these might work??
ed4copies
Local Chapter Manager
Racine, WI, USA.
Thanks for sending business our way!!! But I doubt that will work. The Dayacom jr series uses .40" and .48" OD with a .01 wall thickness, for an inside diameter of .38 and .46 approx. The "JR" from Timberbits was slightly different, people noted that the bushings for the Dayacom jr series did not work. I suspect you are SOL> the parts were completely unique.
