Jr Gent stylus conversion
See more from MarkD
MarkD
Sayre, PA
This is a Rhodium Jr Gent 1 pen fitted with a CSUSA stylus tip.
The blank is Mexican Agate Tru-Stone. This has to be one of the most beautiful Tru-Stone blanks I have seen.
The pictures don't do it justice.
As always, your comments and critiques are welcome.
Thanks for looking.
Joe Burns
Temple Texas
Mark,
That is the best stylus conversion pen Ive seen. Beautiful blank and well executed. Did you have to do anything special to get the stylus tip to fit the end of the Jr. Gent?
Joe
SDB777
Cabot, Arkansas USA
Will that stylus work on the iPad? We've been looking for one that works all the time without having to re-engineer a Walgreens styli.....
And your right, that blanks is awesome, and photo'd very well!
Scott (on a rock too) B
MarkD
Sayre, PA
Thanks everyone for your comments.
To adapt the CSUSA stylus to the Jr Gent. I chose to made an aluminum adapter. I cut some 8x.75mm threads on the aluminum then drilled it and pressed the stylus tip coupler into it. The challenging part of this conversion was the spring. Originally the spring fit inside the end cap. When replacing the end cap with the stylus there was no room for the spring. After exploring several options I decided that since I had some 10" sections of 10mm brass tube, the best approach would be to use a longer brass tube and longer blank, and contain the spring in the tube. The new tube and blank are .400" longer than the original.
I'm sure there are many different approaches to this situation. I'm not claiming that my approach was the best approach but I'm happy with the end result.
Here is a picture showing the adapter along with the other pen parts.
MarkD
Sayre, PA
Yes, the stylus works on all the "i" devices I have tried ( iPhone, iPad, Ipod touch ) as well as any of the tablets I have a chance to try it on.
The only problem I have incurred so far is that the CSUSA stylus trim rings are presently only available in chrome.
Smitty37
Passed Away Mar 29, 2018
Milford, Delaware 19963
Nice job
That is a great looking pen. If you get a fountain pen which doesn't need the spring it looks like it would be plug and play.
MarkD
Sayre, PA
Thanks Smitty! I thought you might like the pen! :biggrin:
Your right, if this was a fountain pen it would have been simpler!
Haynie
Page Arizona
Typical. I been trying to figure out how to do this for my brother's Christmas present. I log on and someone has done it. That is one sweet pen you did.
MarkD
Sayre, PA
Thanks! I usually find where someone shows something right AFTER I finish a project. :)
bitshird
Adamsville, TN, USA.
Outstanding conversion Mark, I agree, I wish they would bring out some different plating, But look on the bright side, at least it isn't 24kt gold!!
Lenny
Searsport, Maine
Mark that's a fantastic pen in it's own right but with the mod it's even better!
I love that trustone blank!
One thing I thought when looking at it ... wouldn't it be cool to take it another step and create a cap that screws on to protect the stylus tip when not in use. Just something to think about ... maybe?
Great job!
MarkD
Sayre, PA
Great minds think alike! In another thread Skiprat offered an idea for a single part that would convert a postable pen to a non postable pen. When I saw it your suggestion came to mind. It would look awesome and protect the stylus but I'm afraid I would probably loose the part the first time I took it off to use the stylus.
http://www.penturners.org/forum/f15...033/index2.html#post1342469?highlight=skiprat
Smitty37
I agree
Great minds think alike! In another thread Skiprat offered an idea for a single part that would convert a postable pen to a non postable pen. When I saw it your suggestion came to mind. It would look awesome and protect the stylus but I'm afraid would probably loose the part the first time I took it off to use the stylus.
I think I agree Mark...It would have to be a small part and the stylus can be used anywhere including walking down the street. I'd drop it into my pocket, forget it was there and loose it when I pulled out change or put the pants in the wash.
plano_harry
Plano, TX 75093
Definitely the best stylus I have seen! Beautiful craftmanship on the pen. I don't like the looks of the threaded post pens from a style standpoint, but I think this works so well it makes the pen look better than the original design. I am going to try one! Thanks Mark! Since I am a beginner, I am going with the FP, per Smitty's suggestion.
Harry
Andrew_K99
Waterdown, ON, Canada
Great job on the pen/stylus!
One guestion though, how is it using the stylus? Do you leave the cap on? After using a small stylus I don't know if I'd like something that large.
AK
MarkD
Sayre, PA
I personally don't care to write with posted pens and the same is true if I'm doing much with the stylus. If I'm in a hurry I sometimes will use the stylus with the cap attached but I prefer to have it off. One thing that's different about using a stylus over a pen is that your typically using it in more of an upright position than when your using a pen, so the weight of the cap does not seem to bother me as much as when using a posted pen.
What I really like about this pen/stylus is that I always have my stylus available since I always have a pen with me.
joefyffe
Passed Away Aug 19, 2018
Indianapolis (almost Zionsville) Indiana
Smitty: I just checked my F/P as I'm thinking about making this conversion on it. Memory tells me this is a Navigator which, if I'm not mistaken is same sizing as the Jr.s. With a converter I'm out of luck but I think I can still accomplish my goal with cartridges.
Smitty37
I know that Mark used Jr Gent 1 kits and I was saying that referring to them and using cartridges...I don't know what the converter would do but I suspect it would extend about as far back as a rollerball refill.
