Is a Slimline kit a sports car, or a Porsche?
CaseyK
Angels Camp, CA, USA
I'm somewhat new to buying kits and have been pretty much with PSI. My question is are the Slimline kits (and by extension the myriad of other kit designs) a general type of design, a sports car with the differences from maker and model and such, or are they a specific design, like the Porsche 911?
I want to feel comfortable ordering the "same" kit from multiple vendors and know that I'm getting what I want, the 911. As opposed to ordering kits and getting potential variations in design/quality/finish because the kit is in fact a general sports car. I've been totally happy with PSI but I'm finding that sometimes they are out of a design/finish that I can find on other sites and want to make sure that when I order a Slimline from A that it's the same as what I would get from B and/or C and as well as what I've been getting from PSI.
So is a Slimline always a Slimline, or are these pen designs more of a suggestion?
Slimlines especially come from a variety of manufacturers... the cheaper ones (Amazon, etc) tend to be Chinese and have less durable plating and higher fail rates in the twist, etc. A good chunk of the kits out of Taiwan (typically better) have Chinese clones with inferior metal/plating. So yes, where you get them from can matter.
When you look at the offerings from the vendors (not Amazon), you will often see 2 offerings for standard twist slimline. One will be cheaper than the other. That's because it is, well, cheap as @McKenzie Penworks stated. The plating will wear off quicker and the transmission will often be problematic. This specifically is referring to the fact that cheap transmissions will often retract when the user applies pressure by writing. As they write the refill disappears up into the barrel. When someone pays the money that we will charge, even slimline money, they shouldn't have that happen to them.
I started penmaking many years ago and I suppose I'm biased from those early years. PSI was the company with cheap kits and poor service. They have seriously expanded their offerings over the years but I still think of them that way. There are a number of psi kit resellers that offer better service and will often save you money on the kits.
Slimlines are more of a Ford or Chevy to me. But they are very customizable, and not a lot lost if messed up.
When I wanted to make something truly individual looking to give away, I often used the Slimlines. BTW, Slimlines can be more difficult for beginners due to two part straight blanks.
I would consider slimline kits the basic sedan of the automotive world. I would not consider them a sports car by any means. You are getting something just about manufacturer provides for its customers and quality varies by manufacturer.
A significant detail which hasn't been mentioned yet is that not every "Slimline" uses the same length barrel tubes - the parts are not always interchangeable between kits from different sources. (No need to ask how I know this.)
Your analogy is interesting but as many have mentioned a Slimline kit of any kind falls into the low end of any car manufactorer and not a sports car or a cadillac. As far as different kits from different vendors, yes this is true. but you can look at the price line to help deciding the better ones. But Slimline kits are not alone. Just about any kit on the market has clones and they can vary in quality. Many vendors call their kits by different names but have a little different design but still same kit. It has gotten worse through the years. Dayacom is and I guess should say was, now that they are closing shop, as the premier kit maker. Every kit they made was quality. Click pens is another one of those talked about subjects that gets kicked around here alot. There are good clicks and not so good ones and they come in many different styles so name of kits are many. But if you go down that path you will see what I mean when you approach here with questions. Good luck. and have fun
I get it that the Slimline "brand" is the lower end of things, I just couldn't think of another car analogy that might work. Basically what I get out of this is that there are differences within the model/design (a 911 from Yugo/Ford would be different from a 911 from Porsche) and the only way to know is to buy. And once in hand I can make the determination.
Thanks for the insight here, it's very helpful.
I would like to hear what slimline kits the veteran makers are buying.
I did funline and trimline from PSI, then moved on to single barrel ballpoint twists.
