I found a drill bit and...
Herb G
Southern Maryland
I have no idea why I have it. There are no markings on it at all.
It is a brad drill bit for wood. It measures 21/64" on my drill gauges.
It is not out of a set. Would this be used in pen making?
If so, which kits would it fit?
I sincerely have no idea why I even have it, let alone know what it's used for. It's bugging me to no end.
Any help out there?
Thanks in advance.
You may be using it for a substitute for the "O" drill bit. I do that. The Flat Top kit is the one that pops to mind that calls for the "O" drill bit.
Herb, that is a fat 5/16 bit. It would be one of several choices to drill for 3/8 by 16 bottle stopper threads.
While I have it in my drill index, can not remember using it for a pen.
The only kits that I'm aware of that specifically call for a 21/64 bit are the Seam Ripper and Euro Letter Opener by Hut Products. Other suppliers of those same kits call for a letter O or an 8mm or a 5/16 bit. While a 21/64 can be used in place of any of those 3 bits, it is about 0.3mm or 1/64" larger - which sometimes can be helpful.
Personally, I wouldn't use it for bottle stoppers though. My personal preference is to use a 9/32 bit. I like to drill the holes a little undersize, then tap them to 3/8-16 before threading onto a mandrel. That's just me though - others have different techniques.
So you found the drill bit....
.......and Mitch found your drill!:biggrin:
Now get back to work!:laugh:
Possibly part of a "loose tenon" joinery kit? If you have 5/16" dowels that are going to be glued in, a slightly oversized hole allows for good glue coverage (too tight a fit means no space for glue, and the joint is weaker).
