I have posted about this before... The subject is mandrels for blind holes, such as baseball bat and desk pens.
I know of three possible ways to turn these:
1. Some desk pens have a tube that has internal threads. A mandrel is available that has threads to match.
2. A mandrel can be made out of a rod with a sharp flat or points that drive the blank. Such is the mandrel that Russ Fairfield uses for the longline pen, as described in his site.
3. The pin chuck. This is my favorite. The blank is driven by cam action. The rod or mandrel has a flat cut on one side, to fit a pin. The pin is put ON the flat, and the mandrel inserted. The pin acts like a cam inside the blank. See pics at these links:
A commercial fixed size pin chuck:
http://www.axminster.co.uk/products/Axminster-Pin-Chuck-23009.html
Fred Holder's drawing of a pin chuck (3/4 down this page).
http://behemothtools.tripod.com/id6.html
To make a pin chuck all that is needed is a rod of the right size to go into the hole in the blank. A flat is ground or filed on one side of the rod, at the end or anywhere along the lenght of the rod. The pin is a little rod that fits on the flat. A good source of little rods in several diameters is COMMON NAILS, just cut a piece and file the ends smooth. Put the pin on the flat, and insert into the blank. Cam action drives it around.
