leatherjunkie
What size of drill bit would you use for the top of a salt / pepper shaker(the end that you would shake the salt/pepper out of). I want the shaker to be all wood except for the plug in the bottom.
Originally posted by ed4copies
<br />There is a metal top available that fits about a one-inch hole (that's the way I have always done it-glue it in) and put rubber "stopper" over bottom of hole (also about an inch).
Originally posted by vick
<br />So I would guess unless you have a 1.5mm bit (.0591), you would be best with a 1/16th (.0625)
