Draken
I just finished off the ink cartridge that came with the Jr. Statesman VII FP. Popped it off, and cleaned out the nib and feeder with cool water until only clear water was deposited on paper by the nib. Let it set out overnight to dry. Lowered the plunger on a Roting internation converter, and connected it to the barrel with a twist motion like the directions said. Dipped the nib into the ink, about 1mm from the black plastic ring that can be seen between the nib and the barrel. The hole in the nib was well below the level of ink. Turned the knob on the converter, and no ink entered the converter. Tried again, turning the knob slower, and still no ink. Any ideas what I may have done incorrectly? This is my first exposure to FP's and converters.
I also noticed that the Roting converters do not have a little ball inside of them, but the converters that come with the Barons does. Does this make a difference?
Thanks for the help! Pen and ink are at home, so any suggestions you give won't be tryable until I get home tonight.
Cheers,
Draken
Cheers,
Draken
