Chrome Galacia Problem
Silverado
Just finished making several of the new chrome Galacia Ball points.I really like the hardware. Had 3 out of 5 kits that the Finial cap would not go all the way on. Do not force the finial cap on as you will collapse the trans.Take a look inside the cap and you might find some casting slag at the bottom.You can easily remove by scratching at it with a small screw driver.
I ordered some new transmissions as the refill won't retract all the way into the pen.
Hope this Helps!
Regards,
Tim
