sbrown
Snapmaker 2.0 Modular 3-in-1 3D Printer A350 with Enclosure
Pick up only. Located in Tucson, AZ More photos available. Just message me for more details.
Bed dimension is 12.6"W x 13.8"L
3d Print Area Height is 13"
Laser Work Area Height is 10.8"
CNC Work Area Height is 10.8"
Currently set up as a CNC. Manuals, tools, hardware for swapping functions, all build plates, googles, extra cnc bits included. Specs included below and in photos. Machine works well. Just doesn't fit our needs anymore. 3D build plate does need cleaned (alcohol works well to do that).
Snapmaker 2.0 A350 offers the ability to do 3D printing, laser engraving, cutting, and CNC carving.
Machine Dimensions: 495 W × 506 D × 580 H mm (19.48" x 19.92" x 22.83")
Enclosure dimensions: 626 W x 820 D x 603 H mm (24.65" x 32.28" x 23.74")
3-in-1 Software
Our 3-in-1 software, Luban, is tailor-made for your Snapmaker machines. It is a free, open source CAM software committed to software services that allow full controls over 3D printing, laser engraving and cutting, and CNC carving capabilities: one single and powerful software for all your tasks. Downloadable online.
Dozens of Materials
This machine supports so many materials that you couldn't even imagine. From PLA, ABS, TPU, PETG for 3D printing, wood, MDF, vegetable-tanned leather, cotton fabric, A4 white paper, white cardstock, corrugated fiberboard, non-transparent acrylic for laser engraving and cutting, to acrylic sheet, carbon fiber sheet, POM, PCB for CNC carving and more being tested.
3D Printing
Snapmaker 2.0 Modular 3-in-1 3D Printer A350 is ideal for beginners who are just getting started, hobbyists who prefer more customized options, as well as engineers and designers who want to print large objects or accurate parts with outstanding print quality. Features: Auto Leveling, Filament Runout Recovery and Removable Print Sheet
Work Area (W × D × H)" 320 × 350 × 330 mm
Max Heated Bed Temperature: 80°C
Layer Resolution: 50–300 microns
Nozzle Diameter: 0.4 mm
Max Nozzle Temperature: 275°C
Supported Materials: PLA, ABS, PETG, TPU, wood filled PLA, and more being tested
Laser Engraving and Cutting
While traditional 3D printers can only 3D print, your A350/A250/A150 is entirely different. A350/A250/A150's functionality can be changed quickly with interchangeable modules, just like changing lenses on a camera. Now you can make many kinds of beautiful and artistic creations with laser engraving and cutting. Features: Built-in Camera, Faster Work Speed, Aluminum Grid Table
Work Area (W × D × H): 320 × 350 × 275 mm
Camera: Built-in camera
Laser Power: 1600 mW
Wavelength: 450 nM
Safety Class: Class 4
Supported Materials: Wood, leather, plastic, fabric, paper, non-transparent acrylic, and more being tested
CNC Carving
You can even use the A350 as a CNC router to create precise 2.5D and 3D objects. It has a more stable work speed and a much larger work area than Snapmaker Original, which is a perfect machine to extend your interest in CNC carving. Features: ER11 Collet, Wasteboard & Clamping Kits, Dust Resistance
Shank Diameter: 0.5–6.35 mm
Spindle Speed: 6,000–12,000 rmp
Supported Material: Wood, acrylic, PCB, carbon fiber sheet, jade, and more being tested
Connection Type
Data Transmission Methods: Wi-Fi, USB Cable
Touchscreen :5 in., Android OS, Quad-core 1.1 GHz ARM Cortex-A7
3-in-1 Software
Dozens of Materials
3D Printing
Wavelength: 450 nM
CNC Carving
Connection Type
