I'm looking for a 10.5mm x .75mm tap/die. I've checked Enco and Victor and banged around a bit online but nothing came up. Does anyone know where I might find this size?
Mark, as you require a tap AND die, I'm assuming you are make both your male and female threads rather than matching to something existing?
If so then would a 10mm x 0.75mm do the trick? This size is readily available as a Metric Fine size and of course will be massively cheaper than a custom made 10.5mm.
