micro mesh
  1. freshmaker
    Finishing (Sanding/Polishing) with Alumilite Clear Slow
    Hi folks, I'm hoping to tap into your collective and generous knowledge to try and tackle my finishing problem. I've been searching around reading various threads about sanding and buffing pens, but haven't found anyone encountering the same problem when sanding/polishing resin. Please redirect...
  2. Hartwell85
    Lathe Speed for Sanding with Micro Mesh Pads
    What lathe speed do IAP members recommend for sanding acrylic pen blanks with Micro Mesh pads? I would be using water as the lubricant. Any tips for using Micro Mesh pads are appreciated.
  3. Woodchipper
    More finishing?
    I had talked about some problems with a pen mill. Another question arises about finishing. Both blanks have CA on them and the CA came out very good, IMHO. However, I wonder about going a step farther with MM. Your advice is most welcome. TIA. Will wait for your replies before final assembly...
  4. Woodchipper
    Micro Mesh finishing
    I use Titebond CA as a finish. I was told that I should go one step farther and use MM to smooth the CA. I didn't get a chance to ask any more questions as the fellow had phone call. What grit/color of MM? Wet or dry? Thanks.
  5. Woodchipper
    Polishing CA?
    I did a search but didn't find anything that I felt answered my question. I don't have a Beal system or anything like it. All I have is basically Micro Mesh and Hut Ultra Gloss liquid. Any suggestions are welcome. Thanks.
  6. BSea
    Micro Mesh Problem
    I recently replaced my old Micro Mesh pads with a new set. Both sets were bought from woodcraft. The old set worked great till the pads finally wore out. The new set doesn't seem to be of the same quality. The abrasive layer is pulling away from the foam pad, and I'm getting small pieces...
  7. Culprit
    Sorting MicroMesh - Colorblind or Not
    A few months ago a guy mentioned here on the IAP that one of the reasons he didn't use MicroMesh was that he is colorblind and couldn't keep the pads in the right order, and that he was tired of constantly asking his wife or someone else to sort them for him. I'm not colorblind, but I don't...
  8. D
    Sand paper trick
    Micro Mesh: or any wet dry sand paper one can increase both it’s efficiency and longevity by keeping the wet dry sand paper or MM clean in plastic containers filled with water. The simple trick is to add several drops of liquid dish ( Palmolive, Lux etc) washing detergent to the water. I learned...
