Padre
- Joined
- Dec 2, 2009
- Messages
- 1,841
Ok, I just returned my third HF pressure pot.:frown: None of them, not one, would hold pressure above 20 psi. The one that held to 20psi only held it for 3 minutes.
I have tried WD40 on the seals. I have tried putting soft silicon under the seal. I have tried making new seals. I have taken off all the hardware that came with the pots and replaced them with high quality brass and wrapped teflon tape around each connection 4+ times. I have marked the tops so as to put the top back on the same way each time. I have rotated the tops to see if that made any difference. AAAARGHHH!!! I give up on HF.
Are there any other REASONABLY priced (sub $250) pressure pots out there that will definitely hold pressure and vacuum?
Does anyone else on this forum use anything other than HF pressure pots?
