What is Tru-Stone?
Rmartin
Columbus, Ga, USA.
What is TruStone?
I've fallen in love with Trustone for pen turning. It didn't start off that way. The first blank I turned was a black with gold web. I couldn't believe how hard it was to turn. Dulled my knife after just a couple of passes. But then I turned a white with gold web and it was like butter compared to the black.
When I sell a product, I like to know all I can about that product. I've been to a dozen suppliers of Trustone pen blanks and they all have a very basic description that it is stone which is crushed and reformed with resin. I can't find who actually makes it. What type of stone is used? What kinds of minerals are used? How is it colored? Naturally?
I would like to add a card to my Trustone pens which gives a clear accurate description of Trustone, but a little more than just crushed stone with resin. Can you help me?
ldb2000
Laurence Harbor, NJ, USA.
Good luck !!! The company that makes it is extremal secretive about it . Several on here have tried to find out but I don't think anyone found out more then "Crushed stone with resin" .
ed4copies
Local Chapter Manager
Racine, WI, USA.
I UNDERSTAND (Not with documentation to prove it) that they had an explosion which has made it difficult to get inventory.
Consider what we "know". If it is rocks made into fine powder, then cast, the fine powder stage would be conducive to explosion. So, the story made sense to me.
But I can't document it, so take it at face value.
bitshird
Adamsville, TN, USA.
Richard, here is a link to the company that makes it, there are two types the Pliable and the older Non pliable which contains more actual stone and less resin, and is nearly as hard as most stabilized Turquoise and harder than genuine Malachite, I used to cut many many pounds of the stuff, but Butch is right, they are pretty proprietary about their process as are most of the stabilizers in Arizona, http://www.rtresearch.net/
They are nice folks, just secretive and you really can't blame them,
OKLAHOMAN
Costa Rica
Tru stone is a product of RT Research corp of Tempe AZ. Their formula for tru-stone is a closely guarded secret. www.rtresearch.net
You might be able to get the formula for Coke easier:biggrin::tongue:.
Gary Zakian
Bloomington, Indiana
Is the easier TruStone you turned the pliable kind specially made for pen makers? Did you use HSS or carbide tipped tools? Have you encountered any problems with sawing, drilling, or breakouts?
I have been looking at doing some TruStone turning, but have not tried it yet, so your input would be appreciated.
Rmartin
Columbus, Ga, USA.
Generally speaking, the lighter colors are easier to turn than the darker. Regular cuting tools can be used on all, but some of the harder need a carbide to keep your sanity. I use WD40 while drilling and have found it drills easier and without chipping and melting as with some acrylics.
PenWorks
Scottsdale, AZ
Man, They make a lot more styles than I have ever seen offered for sale...
Yes they make alot of styles, but only a dozen or so are the PLIABLE tru stone, which we use. The other stone they make is more for jewelry and cut with lapidary equipment. Also as most know, some of the pliable IS NOT that pliable :eek:
Ed, I was down there after the explosion. They are damn lucky no one was injured or killed. Took out several walls. I believe it happened when they were cleaning the tanks with acetone and some vapors built up and Kabooy.
toddlajoie
Feeding Hills MA
Quick question for those who work with this a lo. I did one pen in the malachite variety, and I really love it, but should I have put a finish on it other than micro-mesh to 12K and then buffing? It seems to have dulled quite a bit in just a few weeks.
