Are Your New Car Tires Old?
leehljp
Member Liaison
Tunica, Mississippi,
Here is an eye opener for me. I never gave it much thought. Many tires are sold as new, and are new - as in unused - except that they may be 4 to 8 years old before being sold.
Click here for a video.
Tires are dated by a numbering system that lists the week of the year that it was made along with a 2 number for year - except if made in the '90's it will only have 1 number corresponding to the year.
Lot of truth in that. Saw this on TV a couple years ago and immediately thought of the set of tires I bought for my van a few years ago and less than a year later they were deemed unsafe. the rubber had hardened to the point it was just like stone. I check the date label on all tires before I let them put them on the car now.
Thanks for enlightening folks to this Hank. I was in the business for 22yrs (retail) and it's something most people don't even consider. Could this have been a reason for Firestones' failures? It really isn't a problem except with new vehicles and small tire shops.
No, I was not aware of that Hank. I was thinking re-treads, but a re-tread has to be sold as a re-tread, not as "New". I do know that a re-tread is better than a new tire. You know most of the "Gators" you see on the highways are actually from brand new tires, not from re-treaded tires. A re-tread is less likely to lose it's skin. A re-tread will wear better than a new tire as well. And they are of course cheaper to buy. It all makes sense too. If you are on an airplane, they only use re-treads. Because the tires have so many miles on them, the rubber and metal is wore in. Old shoes are always more comfy than new ones.
Firestones were failing because the Ford recommended pressure was below the safe rating for the tires.
I work in a tire manufacturing facility and you are correct that they are dated by week and year. As many tires that are produced in a day with the exception of maybe some specialty tires i couldn't imagine some being sold years later. not saying it doesn't happen though.
