Help with first bullet pen
Stillwater, OK
So I made my first bullet pen today. I'll post pics later in the 'show off' thread but I need some help. The 7mm tube didn't fit inside the bullet perfect at either end. So I remembered seeing a tutorial about soldering in the tube, but couldn't find it again for reference. Anyway, I glued in one end and soldered in the other but I couldn't figure out how to get the tube perfectly centered in the hole. So when it was complete the nib and upper barrel were slightly off-set from the lower barrel. Not too much but enough I won't try to sell it (when I start trying to sell them...) So how do I keep the tube centered in the bullet while it glues or is soldered?
Thanks for your help!
Mike
That's EXACTLY why I use 25-06 ammo. The 7mm tube is too big to go all the way through and it centers itself PERFECTLY on the shoulder of the casing. If you drill out the primer end correctly, everything lines up and you're good to go.:wink:
I wrap a couple pieces of tape around the tube near the bullet end to center in the casing, and then solder on the back end. Once done I can pull the tape out and press in the nib. The solder on just one end is strong enough to hold IMHO. I've got a couple pens out to friends and I haven't had one come back yet.
Mike,
I've made thousands of cartridge pen kits. When I first started, I glued the tubes in, but since have switched to soldering. A good glue joint is plenty strong, but a good solder joint simply has better longevity. With practice, soldering isn't really any more difficult than gluing anyway.
As you've already seen, it is critical to keep the tube aligned while soldering. With heat and as the solder flows, the tube develops a tendency to float and wander. I also had several failures in my initial attempts so I can sympathize.
If you are using a real bullet (as I do), you can center one end of the tube on the bullet base. You'll need to develop a technique to keep the tube down while soldering. If you are planning to press a kit part into the case mouth, you'll need something to keep the tube centered. A dedicated jig works best, but you can also get by with spacers made from larger brass tubing, or even just tape. I've used tape on occasion.
Keep trying. With practice, you'll find a process that works for you.
Regards,
Eric
Thanks guys, I'll keep trying. One of my problems was that even in the primer end that I drilled with a 7mm bit, the tube was a little small. So it didn't fit snug in either end. I wonder if it was the kit, but all the parts pressed together good, so I don't think so. I'll figure it out or I'll just buy them from whoever sells them with the tubes in them...I don't make enough to warrant putting too much time and effort into it...LOL....Who is the member here who sells the casing with tubes in them?
Hello I have made hundreds of bullet pens and I use 5min epoxy to put the tube in place it gives you enough set up time to center your tubes perfect and when dried is just as strong as anything else.
JIM
If you have a set of letter size drill bits, try using bit "I" instead of "J" (typically sold as 7mm). It is a much closer fit for a 7mm OD brass tube.
If you are looking for just the tubed 308 case (no bullet) for use with a slimline nib, Gary Max has sold them as long as I can remember. He has a listing at http://www.penturners.org/forum/showthread.php?t=56288.
If you want a complete rifle cartridge (case with drilled real bullet for the nib), I've been selling them in a variety of calibers for years. You can view and order online - follow the link in my signature.
Regards,
Eric
