Clock
See more from Sylvanite
Sylvanite
I had a piece of mineral-stained poplar lying around, so I turned it into a clock.
Eric
Nice job. Did I mention I like clocks:smile:
Just a suggestion and this is just an opinion. But when making full faced clocks from a slab of wood I always find not using all numerals is more eye appealing. If you want to designate the numerals uses dots or dashes in place. The numbers 12, 3, 6, and 9 can be used. Love the wood grain. Thanks for showing.
...when making full faced clocks from a slab of wood I always find not using all numerals is more eye appealing. If you want to designate the numerals uses dots or dashes in place. The numbers 12, 3, 6, and 9 can be used.
Yes, that was my original intent. When I did a test engraving, however, it looked too sparse. If the clock had been smaller, I would have stuck with just 4 numbers (and they would have been proportionately larger), but at 9.5" diameter, I chose to use all 12.
Generally, though, I agree with you. One wants the eye drawn to the grain (or figure) of the wood -- not the numbers.
Regards,
Eric
Regards,
Eric
You would have been right on the mark Eric with the larger numbers and dots or dashes. It still looks good, don't get me wrong. I love the grain in the wood.
Nice work!
I just finished a clock (I'll get pictures up to prove it :-) but wasn't ambitious enough to put on any numbering. I think the numbers look very elegant on your design and complement the figure in the wood nicely.
-Barry
