Orange
Jgrden
hOUSTON, Texas
Help me understand how to know what amount of dye to add to Alumilite to change the color? Test it in small amounts first? Can you mix the entire amount and get what you want by looking at it before it is cooked? I watched their video and they sure make it look easy.
I don't use Alumilite, but with PR it depends on how opaque you want it to be. Yes, I can tell by looking at it, but I measure everything and already know about how much to add on a new color from the past colors I've done.
If you are using the Alumilite dyes, it takes very little to color the resin, but they remain translucent, at least with PR. It doesn't matter if you add more either.
What you said has helped me. I know now to paint the tubes just from what you said. Thanks for saying something. I realize my message was fishing for any remarks and yours was what I wanted.
Sorry, I just saw this.
The nice thing about mixing the dye with Alumilite is that you do it BEFORE
you mix with Part B. So .. keep adding till you get the look you want,
then double it and add your Part B.
Alumilite dyes are pretty intense. If I'm mixing one or two blanks, the hard
part is getting a small enough amount of dye on the toothpick.
Yikes - TOOTHPICK ???? Are you pulling my leg?
No, he isn't. They are Very intense colors. If you want subtlety using their colors, make a BIG batch. Or make enough for one blank but add the colorant one toothpick dip at a time. One drop will be "unusable".
GK
My gosh, thank you. I need to make 6 orange flash drive pens and two red ones. All with decals and names embedded in them. I need to make the molds, color, mix, turn, label and finish. I cannot afford to make a mistake on the intensity of the colors.
If it will be translucent only, then it isn't as much of a concern.. it will get
deeper/darker, but still translucent. But no need to waste it, either.
Kinda surprising how little it takes.
I have to disagree with one portion of NewLondon88's post above...forget the Alumilite direction on adding the dye to the A side before adding the B. Alumilite is supposed to be changing their directions the next time they have dye bottles printed. I have helped a lot of folks with problems they are having with Alumilite and the #1 reason for failure for newbies by far is they are not getting it mixed thoroughly enough. One huge advantage of mixing A&B BEFORE adding the color is that you can tell when you have it completely mixed. When you first add the 2 parts together, they will look cloudy and streaky. When the resin is thoroughly mixed, it will become absolutely clear with no streaks. That is why I always recommend clear cups too. It lets you see into the resin as you mix. After it is completely mixed, then add your dye. Doing it this way will guarantee success and accurate color. If you add the dye to the A side and then add the B, you will not be able to see this transformation and you are just guessing at when you have it mixed enough. With experience, that is fine but just starting out, you are likely to have issues with under mixing.
Alumilite says to add the dye to A then add the B because the carrier for the dye is A based. If you were to add a bunch of dye, then you could skew your ratio a little and affect you mix. However, as said above Alumilite dye is so concentrated that it take so little that it will not mess up your ratio at all.
I transfer my dye into empty CA bottles that you can get from Monty. This makes a built in dropper and makes the dye much easier to handle. Then I add 1 drop of dye per ounce of mixed resin and have very strong, beautiful colors.
Pens - 12-9-09 Mold - Red Experiment.jpgI labeled all the tubes, three to a pen (memory sticks) loaded them with BB's, plugged the ends, stick them into the molds, mixed and poured the Alumilite. All this in 70 degree temperature. Stuck it in the pressure pot, immediatly started the compressor and I think it blew a head gasket - no pressure. Tool the molds out after a half hour passed. There weren't any bubbles. I baked it at 150 degrees for 30 minutes. Pulled it out to cool. It was clear but at this stage I could see air surrounding the tubes and this is not good. I am hoping as it cools and contracts it seals itself to the tubes and the lettering becomes clear.
I experimented with the red dye and just as you said, it is powerful stuff. Any and all comments are welcome, as Jack (Jack in the Box) says, "I can take it".
Not sure with Alumite but I know with PR that if it doesn't cure enough and you put it in the oven too soon, you will get bubbles. PR has to be pretty good and cured before you put it in the oven.
I don't use Alumite but do you even have to post cure it with an oven?
Nope. Don't need to post cure it. Why did I do it? Dunno. Maybe for that extra degree of hardness??
Thank you for reading , looking and commenting.
No post cure that I know of.
PR can get funny with sudden temp changes before it's cured. I know pouring
warm resin into a cold mold isn't good, pouring cold resin into a warm mold isn't
any better.
I haven't been on in a while.
Depending on what you want (translucent/opaque) you might find a suitable recipe in my Resin Color Library . In the cases I've tested, I found that if the recipe uses only dry pigments (no liquid dyes) you can interchange Alumilite and PR.
