DennisM
Well I will unmold it tomorrow and see if it worked! Figured I had just enough CC to make a small mold, and since I do not plan on using it again with switching to s41 why not try something.
Inserted a tube over a wooden dowel, nice and tight to prevent resin from getting in the tube, then used a scrap peice from prior mold and drilled the center to hold the dowel. Inserted it in the cap and then added the length of tube around it.
Poured resin and now waiting to see If I get lucky and have no air bubbles around the tube.
Will let you know then what was wraped around the tube..
dennis
dennis
