BigguyZ
I have a ton of old circuit boards that I could easily chop up and never miss. So,I'm wondering how you would go about making one of these blanks? Do you simply heat the board up and wrap around the tube?
Thanks!
Thanks!
Do you heat it up and remove the solder and components? surely at least the big ones like memory and caps and such yeah? Some of these thing would be way too thick for even a monster sized pen.
The problem with the 'flat' method is that you will be drilling right through the board, leaving nothing but empty PR with a sliver of board on each side.I don't use "heat" to remove the larger components. A trusty pair of pliers to remove some of the "heat sinks".I like to keep the (small)"resistors" on the PCB since it gives it a "nicer look".They lie fairly flat to the board. Will post(pic) once the cast is dry. Trying to match it with a chrome Sierra. Size should be ok.
Hello, Where can I buy some circuit boards. Carl, Mesa, Arizona
Could you take a good color picture or scan it in color and use that on glossy photo paper to wrap the tubes and get the same effect?
I asked this question in another post here and got no answers but it looks lioke there are some electronic gurus here. The new circuit board blanks that are coming out are orange in color. Is this a popular color in the circuit board world.??? I ask because people will ask me where the board comes from and I am not into electronics so I would not be able to answer them. Is there actually orange boards and would they be used in computers or elsewhere??? I know Bruce used to make red and blue ones and I have a couple of those but they are truely circuit boards. Not sure these blanks are even replicas of a true circuit board. What do you all think.
instead of a torch, maybe an electric heat gun?
http://search.harborfreight.com/cpisearch/web/search.do?keyword=heat+gun
What I would like to do is figure out a way to mount a small battery with in the tube and design a board with little leds that flash or stay on. That would be a neat little project.
Scott
Attached are a few pictures of an inner layer PCB laminate. The sheet measures only 0.005" thick and could make for a very interesting base material for my first pen casting project. As you can see by the pictures, this material will easily wrap around a slim line tube.
As for working with an assembled board, if you have a thickness sander, you could make a sled that holds and supports the assembled board while you gradually sand the thickness down.
Scott
So I'm assuming that's a single PCB layer, prior to it being added to more layers of a PCB and having the components being added? That's cool, though I like the idea of having the old surface mount components stil being on the PCB...
I wonder if there are suppliers that would provide just an inner layer or top layer of the PCB to users? For cheap, I mean.![]()
