glycerine
I like to call this one "Tetris"... It's a walnut and aluminum segmented rhodium jr. gent. I showed this to a friend and he told me I needed to take it to a bricklayers convention... ...not a bad idea!
Wow! That's cool. Is the aluminum hard on the tools?
Spectacular! Inspiring, too, because I just got a really cool idea.![]()
Do share with the rest of us!!
Nice work!
How many rows are there?
On a piece like this, how is the ca/epoxy adhesion with all the glued surfaces. I can understand 2 pourus surfaces, but how about the wood against a smooth surface. Have held back from these with metal/plastic in due to this thought. Is it, maybe easier than I think?
Patience, grasshopper:tongue:
Actually, your title gave me the inspiration to create a blank that actually depicts a Tetris (LOVED that game) scene with several blocks already in place and another falling. Now I just have to work out how to make it look good.
Great pen, how did you avoid staining the wood when you sanded the piece, usually the dust from the aluminium will stain?
Very nice work. The aluminum and walnut look great together. If you build it so that the pattern repeats 6 times around the blank, instead of eight times, then the pattern will always line up, regardless of which thread you use when placing the cap on or posting it.
I will have to try that, I have been having bad luck with CA finish ? and dust from aluminium.
