Charlie, thanks for the pics! It looks like the purple color all but disappeared with the Alumilite dyes..
:frown:
Yep .. and most of the orange, too. I wanted a really bright, vibrant
tangerine pearl, which I get before it cures. Wonderful colors.. and
the purple was a deep royal color, looked like velvet.. maybe a king's robe
or something the pope would wear. As you can see, the color didn't hold
up.
If I am reading correctly, you said that the transparent dyes from other sources were either too diluted (I hear ya) or turned the PR opaque (?).
They give a tinge of color or they get milky. You can see from the orange
dye, that the color is deep, but still very clear. Some of the blanks I want
to do need this depth and clarity. For instance, if I mix part of it just
color and part of it color with pearl and then swirl the two, I get a deep
color, but a 3-D effect at the same time.
I need a dye that can give me a deep color, but I can still read through it.
The opaque PR dyes I have work fine (colors aren't great, but not terrible)
but to custom mix colors, I need translucent dyes that won't change
the opacity. The ones I get look like I'm seeing the suspended solids in
the dye.
First, this seems to be a consistent issue no matter the dye, so try using a different base. Maybe you happened to get an old or off batch of PR???
If you want, I can send you some of the stuff that I use.
This is many batches of Silmar 41 and Cast'n Craft. But it isn't the resin,
you can tell by looking at the dyes right in the bottle.. they're not clear.
Wait .. you mean .. there's workshops that DON'T look like this?
