W.Y.
When Bruce (gofer) was in my area recently he brought me some odds and ends of wood. Among them was a very heavy 2.5" thick x 8" wide laminated red oak mantelpiece that had been taken down from somewhere. There were some screw holes in the bottom but I was mostly able to work around them and where I couldn't I filled them .
I got enough to turn two bowls the size of this one and then last night I cut two pieces 16" long and glued and clamped them together for a piece 16" square . I think there is enough left for a third bowl or some other form of turning .
Thanks again Bruce. That is an awesome piece of wood.
This afternoon I cut a 16" circle out of that and I now have that big heavy blank mounted on my lathe on a 6" faceplate and a whole bunch of screws . I have a plan for it if all goes well .
I might even do a little tutorial on that one.
More on that later . . . .
I put a walnut oil, beeswax , carnuba wax finish only on this 8" one.
It doesn't give much of a shine at all . I have had that mixture sitting at the back of the bench in a jar and only tried it once before. It feels rather waxy to the touch. How many coats of that are normally applied and do you power buff it after a certain curing period or just leave it as is with a little hand buffing. ?
