Black/Grey Swirl Ebonite Bulb Filler....
See more from bgray
bgray
Milan, OH
This is a bit thinner than my typical bulb fillers, maybe a bit more elegant.
Wonderful design and stunning craftsmanship Brian . Do you use a mortise and tenon joint where the ink window and the ebonite join or just a butt joint ?
That join is threaded and epoxied. It needs to be ink-tight, so I feel better with precise threads, sealed with expoxy.
This will also add more strength than a mortise and tenon, and much more than a butt.
Thanks.
