223 Rifle Casing Key Chains
See more from keithlong
keithlong
Athens, Alabama
I was in the shop this afternoon and decided to try an idea i had in mind to make a key chain out of some 223 casings. They are a little small for pens for me. So i decided to make the end for the key ring out of some antler and turn a tenon that would glue in the neck of the casing. I was pleased with the way they came out. I plan to make more. Hope you enjoy. Thanks, Keith
Very nicely done Keith. They are very good sellers I have found.
I do mine a little different because I think it looks more like a bullet if the key ring is in the back of the shell. I happen to use real bullets only because I have them for my cartridge pens.
Maybe you could turn a wood bullet if you do not want to get the real thing. Just a thought but thanks for showing. By the way here is a poor photo of mine. I do need to take a better picture but you get the point.
Keith and John, the bullet key chains are great ideas, John what do use use in the ends to hold the key ring and where can I get some?
Pat
Pat
Thanks for the kind words. I get my kits for those here. http://www.leevalley.com/wood/page.aspx?c=1&p=32826&cat=1,330,43243,50237&ap=1
I like these alot better than some of the cheaper ones because the key ring swivels. Just feels more confortable to me.
Sorry Pat I did not see the other part of your question. These kits are a regular kit with a tube like used on pens. I drill the casing and solder my tubes in and the ring body just press in. I also powdercoat my casings clear. Keeps from tarnishing. As you see I also use real bullets. Have a great day.
You could maybe get crazy creative and turn the lead into a nib, or replace the lead with a nib, and use the guts from a teachers pen and make a bullet keychain pen???
factory slimeline nibs only fit flush on 30caliber. shells.
223 is 22caliber. shell.(you will have to use bullet or turn a bullet)
some 30 calibers are; 3030- 308 -3006 -300 win.mag -30 cal carbine -there are more just can't find my book that list them.
