Joomla Help
hewunch
Albany, GA
OK I am trying to learn Joomla, but I am getting some errors and I do not know how to correct them.
For instance, my main menu on my local host in Xammp lite says
Warning: Parameter 1 to modMainMenuHelper::buildXML() expected to be a reference, value given in C:\xammp\xampplite\htdocs\joomla15\libraries\joomla\cache\handler\callback.php on line 99
On my main menu page (menu item manager) I get these errors
Warning: Parameter 4 to JHTMLMenu::treerecurse() expected to be a reference, value given in C:\xammp\xampplite\htdocs\joomla15\libraries\joomla\html\html.php on line 87
Warning: array_slice() expects parameter 1 to be array, null given in C:\xammp\xampplite\htdocs\joomla15\administrator\components\com_menus\models\list.php on line 143
Warning: Invalid argument supplied for foreach() in C:\xammp\xampplite\htdocs\joomla15\administrator\components\com_menus\models\list.php on line 147
Warning: Invalid argument supplied for foreach() in C:\xammp\xampplite\htdocs\joomla15\administrator\components\com_menus\views\list\view.php on line 65
Help would be much appreciated.
What version of xampp did you install? If you installed 1.7.2 thats probably the cause because it has php 5.3 in it and joomla is not ready for that. If thats the case, try installing 1.7.1 and move your joomla files there.
OK this was a fresh, I am just learning install. SO I copied my joomla folder out and then uninstalled 1.7.2 . Then I installed 1.7.1 and now I can't get the local host to respond. To be a great program, it sure is a pain to get set up right. Any help, would be greatly appreciated. (yes I rebooted between the uninstall and install just in case)
After the install, did you run the apache_start.bat file in the installed directory?? Thats the only thing I can think of off the top of my head.
Ahhh, I see now... I believe I was correct. Your Joomla program is/was calling out to a non-existent database.
You will probably need to configure a server database to go along with it unless it was installed with something like Fantastico. Programs like Joomla, vBulletin, bbphp require a database like Apache or something equivalent.
Does your host offer the ability for you to configure a database (not all do)?
A database like Apache? And all this time I thought Apache was a Web Server? :wink:
Actually all the Joomla's I have setup, I cheat and get XAMPP.
http://www.apachefriends.org/en/xampp.html
It installs everything you need on the "backend" to make Joomla work.
Good Luck!
-Doug
Doug, I think xampp is my problem. version 1.7.2 was working, sort of. version 1.7.1 is totally pooched.
I've never tried joomla under xampp.... I'll give it a shot when I get a chance, then I can hopefully help a bit more. Maybe Doug will have some other thoughts, but I'll let you know if I get a chance to look.
Yes you are correct. Sorry, my bad in trying to reply to this post, wrangle my kid and pack my car for a 2 hour road trip at the same time. That's what I get for not fully proof reading what I just wrote and just hitting "Submit Reply".
I meant to say a database like MySQL or such.
Ok I got Xampp 1.7.1 running. But only if I go to http://127.0.0.1 not //localhost/
That said when I try to go to Joomla with the install directory intact, it says delete the directory. When I try to go to Joomla with the install directory deleted it says "Database Error: Unable to connect to the database:Could not connect to database"
Funny thing is, I am normally really good with computer stuff (ok mostly hardware, building, repairing, etc). Totally frustrated.
Oops!! That last set of errors (the db ones , not the localhost) is because we brought over the joomla directories, but no the DB one I'll bet. Thats my bad... I should have had you save both. I'd recommend a new install of joomla on the 1.7.1. Hopefully you hadn't done anything with it yet as any changes are gonna be tough to get back.
It was a fresh joomla install too??? I though you had saved your joomla directory from 1.7.2?
If I get a chance today, I'll DL xampp and give it a shot.
I did save my directory, but I also tried just going at it fresh. If it helps, I am running Vista Home Premium 32bit. Thx for the help! I think I will like Joomla... if I can ever get it up and running.
OK..... I tried it... did it roughly in the same order as you. Heres what I learned
-- Joomla doesn't like 1.7.2... NEED 1.7.1 for sure.
-- Uninstalling xammp under windows doesn't guarantee it to be clean no matter what... I used the zip installs (just unzipping into a directory vs using the installer .exe) and windows still keeps some processes at times.
-- to be SURE 1.7.2 is gone completely delete the directory, which might require killing processes (mysqld, xampp_????, and apache are all possible problems).
Once 1.7.2 is gone, install 1.7.1 (again I used the zip file instead of the exe but either should work). Then start the xampp using xampp_start.bat or the xampp control panel. Make sure that you can get to http://localhost then you can install joomla.
If you have more questions, I have it running now and should be able to answer.
