Slim Line Pine Cone
See more from maxman400
maxman400
Omaha Arkansas
This Slim Line has two pine cones on it they were stabilized with CA from the out side and after drilling I used thin CA on the inside before installing the tubes with thick CA. It has 8 coats of thin CA cured with accelerator and MM to 12000. The back of each pine cone is the middle of the pen.
Comments are welcome, Thanks for looking. :smile:
very nice. been trying to figure out where to start on a pine cone pen.
I start by finding dry cones that did not open, and I square them up on the band saw and use a lot of thin CA to stabilize them before drilling. I try to drill down the center of the stem, then use thin CA down the center of the hole then install the tubes and turn Re-stabilizing every now and then. I block sand to final shape and finish. :smile:
