World's largest pen blank!
See more from Rmartin
Rmartin
Columbus, Ga, USA.
OK, maybe not. But It's certainly the largest I've turned on my Jet mini.
Started with a 4" x 4" of red oak and ended with 3 1/2" round.
It's 28" long!
I have about 5 more to make for the piece I just started, and it needs to be cut in half lenght ways. I'm going to need to make some kind of jig to cut it on my bandsaw.
Looks like you did a nice job keeping the diameter the same the whole length.
A suggestion that might save you cutting them in half on the bandsaw. Turn the pieces using a paper joint. Glue two pieces each 2 x 2" together but with a piece of kraft brown paper between them. The joint will be strong enough to hold together during turning but once you have rounded the piece, a sharp tap with a chisel will split the two apart at the paper joint yielding two semi circular pieces.
Hint: cut them while still square and glue back together with a sheet of paper between them. You be able to split them apart later on the paper line with a sharp chisel.
I hear what you're saying about using a divider between the two pieces. I had thought of using carpet tape between the two pieces with a round piece screwed to each end to hold them together while turning, but I was afraid I would not get the pieces dead center when turning and the two halves would be different sizes. I was able to get it lined up right on the center line, so maybe I will try the paper glue up on the next one.
I can tell you it was a bit scary turning on the lathe for the first time. I uesd a long stick while standing way back and to the side.:biggrin:
