This is a message from 2005 in the Yahoo penturner's group. Henk knows much more about the chemistry of glues than I will ever know:
BLO / CA Chemistry
	Linseed oil, a (semi-)drying oil, will polymerize under influence of oxygen/radicals. The double bonds in the linseed oil fatty acids 'connect' to each other, and because there are three fatty acids in each molecule, this creates a 3D network of polymer molecules, i.e. a resinous 'plastic'.
	BLO, a linseed oil with catalysts added, polymerizes a lot faster, but yields basically the same resin. Since (B)LO is yellow to begin with, the resin also is. Due to light influence over time, LO resin will yellow some more. Can't think of anything that will turn it black, other than fire, sulfuric acid, or maybe a wrong catalyst (or way too much of it).
	That being said, the CA/BLO resin is a completely different resin. In BLO, the cross-links occur between individual fatty acid residues, so the triglycerides (the BLO molecules) are attached to one another, creating a true resin. In CA, the cyanoacrylate molecules attach to one another, creating a polyacrylate linear polymer. In CA/BLO, the cyanoacrylate monomers and oligomers (short chains of CA molecules in the process of becoming a polyacrylate) basically act similarly to the catalysts in BLO, in that they accelerate the activation of the fatty acid double bonds. In contrast to the normal BLO reaction though, the CA mono/oligomers actually attach to a fatty acid, then attach another CA or BLO molecule on the other end of their chain. You basically get a resin in which CA mono/oligomers form bridges between the LO molecules, so you get a copolymer resin.
	Interestingly, it should be possible to control the average CA chain length in the bridges, thereby influencing the properties of the resin. Whether that can be done by time control, temperature, additives, or choice of CA (thin, thick; methyl, ethyl, octyl, etc), I have no idea. Don't even know whether any research on CA copolymers exists. Haven't found it yet...
Cheers
Henk
====================Heisenberg was right!=========================
| Dr. Henk J.M. Verhaar     |                                    |
| Principal                 | e-mail:
hverhaar@environcorp.nl    |
| Ecotoxicology specialist  | home:
henk@stichtsend.xs4all.nl  |
| ENVIRON Netherlands B.V.  |                                    |
| Zeisteroever 17           | phone:  +31 30 698 6218            |
| NL-3704 GB Zeist          | fax:    +31 30 698 6239            |
| the Netherlands           |                                    |
====================Uncertainty happens!==========================
Personally, I find that the medium CA I use hardens much quicker with BLO than plain CA. I do not use CA accelerator due to the potential to cloud the CA if you use to much accelerator.
