Where to get Brass stock
watchman7
Cumming, GA
I want to make some pens using aluminum and brass inlay. So far I have found the aluminum I need but can't find brass.
Can anyone steer me to a place where I can get brass stock, i.e. various size washers, sheet stock, or other forms that it is sold. I have looked through the local big box stores and they don,t carry much in brass.
I buy brass sheets of various thickness from the local ace hardware store. They also have sheets of tin, but they don't work as well as aluminum.
welding supply or parts house has brazing rods made out of brass just scrap off white flux coating. A lot of guys around here use them for pins on their homemade knives ,they tell me they are cheaper than ordering them.
Here are three good sources for metals - It may be obvious, but there are different grades/fromulations of all of these metals and they machine differently.
onlinemetals.com
smallparts.com
MSCDirect.com
Then there are those alloys that are custom made using a crucible and forge in the back yard -- notably aluminum/brass mixes. Some of these can be interesting if you run into someone who like to make metal hot.
Mike-
You have to go down to tucker. Handy Ace Hardware has everything.
I had to leave the chapter meeting early on Saturday because our AC went out. Several calls later I found my favorite HW store was the only place open that still had the capacitor that I needed. I have bought a bunch of metal, polish and several other things there over the past couple of years. They are a little bit pricier on some things, but I don't mind paying a tad more knowing I can get anything there.
Here's their address and website:
Tucker
Handy Ace Hardware Inc.
4351 Hugh Howell Rd.
Tucker, GA 30084
(770) 939-6842
Store Hours:
8:00am-6:00pm, Monday-Friday
8:00am-6:00pm, Saturday
http://www.handyacehardware.com/
Eric
I got my aluminum bar stock from Speedy. I get my sheet stock from either Michael's or Ace Hardware, depending on where I happen to be going when I need some.
Another source is your large local auto parts store. You can by Brass shim stock of various thicknesses. Just tell them the thickness you are looking for, or ask them what they ahve or can get for you. Be sure to clean all brass good with a degreaser like Naptha or DNA before glueing on inlaying.
My local Ace Hardware has some great 3/4" x 24" strips in different thicknesses, and for a reasonable price.
Try these guys....http://tinyurl.com/m4dx25
It's called "Monster Slayer" and they have a little of everything. If you want brass, try the "red brass". It's alot softer than "yellow brass" and turns easier. It's not really red, but if you hold the red and yellow together you can tell the difference. It still looks gold colored when you put it in a pen. Red brass is alloy 230 and is 85% copper and 15% zinc. Yellow brass is alloy 260 and is 70% copper and 30% zinc.
Check out this site, they have alot of neat stuff.:wink:
Georgia metals
Hi Mike
Try looking in Gainesville. It is close to you and there used to be a place called "City Plumbing". They had every king of metal you could think of. Also Highland Hardware on Highland Avenue in Midtown Atlanta had a great selection of brass and aluminum bars. The little Ace hardware store of Dawsonville Hwy used to have a great selection of metals, but I moved from your area awhile ago. Hope this helps.
A gentleman was purchasing a copper grounding rod. It was eight feet long and cost $11.49. It looked (I did not check) to be at least 1/2 thick. Now don't you think that would keep a contemporary turner happy for a while???
Hey that's a good idea!
Grounding rods are only copper PLATED. I WISH I could get a solid copper rod for that price!:wink::biggrin:
