onewaywood
Could someone please post pictures of a sled for cutting 45 angles on the band saw
simply ones please I'm terrible at making jigs.
I did after 30 min. I gave up Ok call me stupid but don't see how that Jig cut's 45's
Thinking I see a business classified coming up!:wink:I'd like to find one that will do all sorts of segmenting like the ones I have seen for tablesaws. An all in one bandsaw sled for penturners.
Neil It could be done, I started to do one for my POC 9 in saw, But now I gots me a big old 12 in crapsman,actually the saw has gotten more use in the week I've had it than it has had since it was new, also making a resaw fence for it and even though it has a miter for it I still have the Rhino file I was drawing to make the sled for my old one, The degree thing is going to be dependent on the size of the protractor, 2.5 wouldn't be bad using a 6 in semi circle, using oilite bushings at the pivot point would be easy enough, too bad there wouldn't be an acceptable way to line the edges of the sliding bar or the channel with UHMW problem would be getting the degree markings legible. I have some 10 degree engraving cutters, I guess even a corian slide would work, Maybe there is a use for that stuff.I'm working on one now. I will post some pictures once it is in a stage that it is understandable, and proven.
Ken, I would rather see the increments in either 1 or 2 degrees. But I'm a little picky about things. :biggrin:
Told ya!! :biggrin: Rob and myself expect a cut. Rob for requesting, me for mentioning. I do take paypal!!!:tongue: 25% is good for me. You will have to negotiate with Rob on his part!![]()
The blade is a Laguna Resaw King. It is 111" long 3/4" wide and I believe it is 3tpi. This thing cuts great and leaves an edge that is almost polished. I have shelved the rest of my blades since getting this one. They are offered for sale in the business classifieds every now and then and I am happy I bought ine.Just curious, what size Blade are you using.... Tpi,etc?
