mitchm
No problem Neil, as long as you pay the postage!
got mine too. Thanks. One question though. I haven't made one before. Do you need to square the end of the blanks or turn as is. It looks like they have been squared but the tube is slightly recessed in the blank.
.....Do you need to square the end of the blanks or turn as is. It looks like they have been squared but the tube is slightly recessed in the blank.
Actually, the tube length has no impact on the tip extension. The nib, ink cartridge, and transmission are one assembly and slip into the tube as a one piece unit. You can not adjust the amount of tip exposure with these by altering the tube length.Secondly, if you leave the resin longer than the brass tube, that will reduce the extension of the tip of the refill slightly.
Just received my pens the other day and turned one of them when putting them together realized one bushing is larger then the other.Is this right?
I will pull the tracking number from your box and see what is happening.Neil
Question for you. Did mine go in the mail??? As of yet I have not received them. I assume you sent them USPS and they have been to my door already today.
What are they measuring?Just received my pens the other day and turned one of them when putting them together realized one bushing is larger then the other.Is this right?
Just wanted to let you know the package with the blanks for myself and for Mike have arrived. Picked it up yesterday at work. They are really nice looking blanks. I am ready to turn them soon. What tips/tricks sheet is Bruce talking about? Is it just for the Sierra Vista?
TIPS & TRICKS
Congratulations on your purchase of your new Computer Pen Kit. You will find these easy to work with. I recommend sanding the ends square. I don't like mills if your not careful you can catch and tear a chunk out. I also recommend after squaring the ends to apply a little thin CA to seal the ends. Also it will help if you sand the blank round before you put it on the lathe. These are a Sierra Vista kit and is fatter that than a standard Sierra. The bushings on a Vista are different sizes the clip end is slightly larger use this as a guide. Try not to go smaller than that .551. Than you can taper the blank to fit the pen. You can get it to fit the Sierra and the Sierra Click. Check my web site for more information, tips and pictures. www.creativeinksbybruce.com
Don't hesitate to contact me if you have any questions or concerns.
Thank you
Bruce Egolf
IAP bruce119
More tidbits of information
The Vista kit uses the same tube as the standard Sierra. The Vista is just a little fatter. So you can use the standard Sierra bushing if you are careful and check the size of the kit parts.
Bushing measurements
I.D. of both the standard and vista is the same .389
O.D of booth of the standard Sierra are .477
O.D. of the Vista are NIB .523 and clip .550
Some information about modifying for different kits
Just keep in mind when modifying the thing to look out for is the 2 orange & black long fuse looking components. They are both on the same end of the blank they are the highest components. You will hit them about .532 see the below. The Vista turns to .551 on the large side then .523 on the nib end. So keep that in mind when modifying. As you get close to the final shape if you are cutting it close you should creep up on it very slowly with a skew scraping just a little at a time. If you happen to hit a component it should be no problem it is time to stop when you sand and I wet sand with micro mesh through the numbers then polish it. The hit component wouldn't even be noticeable.
John,Neil, just wanted to let you know my order came today and whenever the rest comes in let me know. Thanks for taking on this group buy. Great to take advantage of some savings.
Just goes to show, they can make it to Australia before they make it 2 states away. John, you are aware that these are not the blanks Bruce makes.
I have learned in the past that I can get something to Europe quicker than I can get it to Canada.
John,
I'm happy to know that they arrived finally, I figure yours took the longest because you are the closest to me in miles. The rest of them arrived today and will be going out tomorrow for you. So if this package was any sign of how it works, you should have them in a week or two.:biggrin:
Neil
Nope, I can't blame them this time, I was waiting for something to come in that I wanted to add into your package. It still hasn't shown up, but you package went out yesterday anyways with a little bit from my current stock.Hey Neil, we need to move farther apart. I still have not gotten the second package backorder yet. Simply amazing how the postal service works.:biggrin:
John, I think I added everything I said I would, but my memory is on vacation for a while, so if I have forgotten anything, please send me a PM and let me know. Thanks.Neil
I got the package today and in it your little surprise. Am going to have to give it a go. Thanks for doing the group buy.
