I've tried a couple different ways with different results, but Here is my one question:
After I apply some medium CA with a paper towel, one coat at a time, making one pass each layer, it looks like you would expect. Semi-smooth but in definate need of sanding. So I go to sand and no matter where I start grit wise, I get the whiteness and it will NOT go away. What is going on and how do I not do this?
I have tried sanding from every range of grits all the way up to 12,000 MM and it's still white????
