Sander Help/Tip?
CountryPens
El Cajon, Ca.
Does anyone have a clever tip for removing the "Clumps" of residual glue left on the Aluminum plate when changing the sanding pads ? My method is not clever and is time consuming.
Thanks,
Lester
I use some lacquer thinner on a rag to soften/remove the glue.
Take the old disc off when it is hot and it is easier to remove
with less left behind glue and paper.
