Cherry Bowl
See more from jharvey1309
jharvey1309
Holstein, Ontario, Canada.
Here is a piece that I finished off last week. I also incorporated some coffee grinds and epoxy in order to fill a void.
Is the black line the void? Did you grind the coffee grinds so that they are fine and then mix them with the CA?
The void was one that I created on the bandsaw. I like to try different things and I figured why not make a controlled cut into the piece and fill it. It was just an experiment that I feel worked out not too bad. The fine line that you see swells into a larger void towards the bottom. You can kind of see it in the reflections. It was finely ground coffee beand miked with epoxy.
