jason_r
I know I've seen this number somewhere, but can't find the post here
or on their site.
What's the density of alumilite (g/fl oz)?
or on their site.
or on their site.
According to the MSDS
Alumilite White
Part A/B - Specific Gravity 1.05
The links are broken to the MSDS for Clear but I seem to recall that A and B had slightly different Specific Gravities from one another that averaged to 1.08.
For those unfamiliar with Specific Gravity this is the density relative to water which has a Specific Gravity of 1.0 so you can calculate how much mass you would need for a given volume of water, multiply by 1.04 for Alumilite White and that's how much mass you need for that product.
I do believe that Alumilite contracts slightly upon curing but thats hard to tell for sure
Now I know why we went metric!![]()
don't know that one, but it is .554 oz / cubic inch.. I'd have to dig out
conversion notes I've scribbled on pieces of paper in the 8th grade..
Ok.. now that I've figured out the reason I couldn't login was
Firefox, I can reply here.
Specific gravity of 1.05 yields:
31 g/fl oz
17.1 g/in^3
OK, I'm lost. Alumilite's web page says .554 oz/in^3
Doesn't that convert to 15.7056 grams?
Yes, way too precise. But from these numbers I don't think the
alumilite site was referring to weight when it said 0.554 - that #'s
on the page for calculating the volume of stuff you need for casting.
Which makes sense, since the densities vary.
I just wanted to measure with my scale instead
of a measuring cup.
of a measuring cup.
T
From the Alumilite website:
Amount of Resin Needed to Cast a Part
top
Note: There is .554 ounces in 1 cubic inch of Alumilite Resin.
Every cast I do is done by weight. Alumilite even suggests equal parts BY WEIGHT.
That's the problem. It should say:
"one cubic inch of alumilite weighs .554 ounces",
or
".554 fluid ounces of alumilite equals one cubic inch"
So which one is it?
Tom
