50 Caliber Parker
See more from rd_ab_penman
rd_ab_penman
Red Deer, Alberta, Canada.
Double Twist Brass and Copper Ballpoint.
Used a once fired Military Casing with a New Commercial Hornady
.510 50 CAL 750 GR A-MAX. Copper Bullet with Aluminum Tip.
First photo shows the completed pen
Second photo shows the Parker Refill Bullet Tip Assembly.
As always comments and or suggestion appreciated.
Thanks for looking.
Les
Hey Les, thats a really nice piece of work! Its probably the first "shell/bullet" pen I've really liked.
Hmmm I like it. I do a lot of 50 cals myself. But I do the cross refill I like keeping the bullet intact. I wounder shouldn't be too difficult to get the drilling rite to have the parker refill set in the bullet without the nib.
Still very nice and writes a lot better then a cross.
Do you coat with anything I don't I like letting the customer have the choice of letting it pantine or get out the Brasso.
Very Nice
Bruce
Very Nice
Bruce
Les' pen does use the entire bullet without an added nib. Like him, I make all of my .50 pens with the Hornady A-Max bullet because I prefer the look of the bullet's aluminum tip.
Boy how about that I didn't know kind of looks like at a glance that it mite have an added stock NIB. I guess if it is an aluminum tip it will drill just fine. I was using the tracers. But I do like the look of the Aluminum tip bullet.
Thanks for the info
Thanks for the info
From my experience, it's actually more difficult to drill these bullets. The aluminum tends to foul the drill bit very easily.
Is the aluminum solid or is it hollowed out into the tip.
If it fowls the drill bit it must be fairly solid making for a lot of aluminum to drill through.
